Agreed. Tiny power has that 2.5" X 3.5" steam cylinder group of castings for $125. That is a really good deal. The rest of the engine can be made with simple plate and barstock. Without machining i.e. lathe and mill, the only alternative is an I/C conversion. The issues: Stroke is typically too short for the bore, steam cylinders are usually configured whereas the bore is about 75% of the stroke. Not exactly sure why that is, but it has been repeated in many engine designs. I/C conversions usually wind up single acting. With leakage around the rings and if there is a crankcase, condensate/water winds up in the crankcase. My experience with Uniflows, while very efficient, if one is after the traditional sound of a steam engine, they aren't going to get it, rather an engine that sounds like a flathead four gasoline engine. The valve arrangement in many of them are of the "bash" design, where the rising piston bashes in to a plunger- opens a valve and admits steam. Noisy and no way to control cutoff. The main issue: While not a huge effort, it takes time to perfect and convert an engine to steam. The end result, although it may work just fine, if it is to be sold, it is simply not going to go for a very high price.barts wrote:At some point, a simple overhung crankshaft running in pillow blocks is easier than a conversion....
If I was in the position of needing an engine and no access to machine tools, I would just buy an existing steam engine at a fair price, use it, if and when it is sold, the entire investment can be recovered, and probably more as steam stuff is increasing in value.
