Really new guy
Moderator: csonics
csonics
Anne from Little Britan
Really new guy
Post by csonics »
Posted on behalf of Alphawolf45:
Alphawolf45
Posted: Thu Jan 10, 2008 3:57 pm Post subject: Really new guy
My first post
.I am studying up to build my first steam engine, boiler and boat...I dont yet know much of anything about steam engines but I am persistant, can correct my own mistakes and very seldom ever finish a job that isnt acceptable to my generally low standards...Hehhehehh
.I have well equipped machineshop - even got a couple cnc mills, all big stuff,, and I do a lot of nonferrous metalscasting ..I have pushed tools for more than 30 years..Its been my work and my passion.
.My hobby workshop is 60 foot square downstairs plus a 20 by 40 foot space upstairs for restoring antique electronics....I am studying steam books to learn what I will need to know.. I am here to look at pictures and be inspired and possibly to share in the enthusiasm by showing pictures once work begins.....
Steven
Back to top
Maltelec
Site Admin
Posted: Thu Jan 10, 2008 4:46 pm Post subject:
Hi Steven
Sounds like you're well suited for steamboats. I've been designing my 1st engine, boiler and boat. Slightly controversial but then again I'd find a "normal" steam plant boring.
I also restore electronic junk. I've been through quite a few computers, though they mostly needed dusting out. I spent most of my time repairing them more than restoring electronics. My era is the 80's where all things were descrete components around an oversized underpowered IC. Lastest thing was a linear tracking LP player.
I work as an electronics technician and have a hobby of restoring anything mechanical or electronic. I recon electromechanical stuff is my favorate. I'd prefer to make things out of transistors and relays anyt day.
I like making things out of junk, and its amazing what you can use as I'm sure you know. Just because its made out of junk doesn't mean it has to look like junk though.
What size boat are you thinking of? Any engine design in mind? Some people say when building a boat you have to displace the water and fill it with money, but I recon most people with the ability to make everything themselvs can make a boat quite cheap. Being close to Scotland I tend to be somewhat tight fisted with money.
Best of luck though and I hope you keep posting your progress on here.
Simon
_________________
Back to top
Alphawolf45
Posted: Thu Jan 10, 2008 5:28 pm Post subject:
Lightning recently knocked out my phone and satellite tv and DRO on my mill and the overhead garage door closer...I dont usually fool with modern electronics but I did manage to fix the phone and the DRO..This modern stuff comes with components that cant be identified by any cross reference books, cant be replaced unless youre in tight with the manufacturer..and I pretty well lost without schematics which cant be had for lot of newer stuff....and then theres surface mount technology- yeuck!!!....Hehhehheh
All these old 3phase lathes and mills with their control transformer and starting relays give me a workout on regular basis..Most every machine I have drug home has required some attention in its control circuits.I tore out the electronics on one old cnc mill and went back in with all new puter and servo drives, variable frequency drive etc..I got an old cnc lathe tore apart now, I fixing it to run off a PC....Knowing a little electonics is fine skill in metalsworking shop..
No I dont yet know enough about a steam engine to decide what I want to build first other than I plan to build a 15 footer of plywood.- will buy the plans for the boat itself...I figure to make every mistake available so that I get the most education from the experience and then will build bigger, better nicer steamer , next year.
I copied some antique rifles as hobby...Thats finally lost its appeal to me. I then thought I was gonna buy an antique outboard engine and copy it...But then I got this steam engine idea..Good opportunity to do something completely new to me...and I showed couple steam boat pictures to my wife who sorta made the decision for me..
Back to top
Maltelec
Site Admin
Posted: Thu Jan 10, 2008 6:33 pm Post subject:
I only have single phase here (thats the problem with living in the middle of nowhere) so I use single to 3-phase inverters. Really handy things, especially as they control the speed as well.
With steam engines you find you can get a really really bad engine to work way beyond any petrol engine would have given up regardless of how old it is. The 1st steam engines were comical compared to even the most basic launch engine now. Yet they worked.
What is difficult is to get the banace just right. 1st of all, the boiler does the work. The engine simply converts heat and pressure into rotational force. This can all be worked out on a calculator, and the numbers don't lie. Every bit of the steam principle can be calculated to the last point and as long as you make allowances for loss of heat and realise that you're never going to get it just right, you can't go too far wrong.
Its all a matter of thinking things out. For instance you want a feed pump to provide enough water to cope with the engines demands in the worst case (going flat out) and a little bit more to cope with all the leaks.
The ammount of steam an engine uses can be calculated quite easily by knowing its displacement, the speed it will run at and the volume that a specific ammount of water takes up at a specific pressure.
The speed it runs at has been an issue right from the start. Fast, slow, very fast, very slow, whats best? Personally I like 400rpm mark. Its not so fast that its a complete blur but then its not too slow that you don't get the power range. The pitch of the prop with about 25% slip should get you about 1.3/1.4 times hull speed. Hull speed is the maximum speed the hull likes to go at. For 99% of steamboats, they will run at around 1.3 times the hull speed. The idea being the hull will not go faster than the 1/2 wave of wash it makes from the bow to the stern. So in effect, the longer the boat the faster it will go. This is of course a rule of thumb and can be worked round should you want a speed boat or otherwise.
The engine power is always the odd one. How much power a boat requires to go a set speed is largely based on the hull speed as long as you have enough power to get to it in the 1st place. All I can say is my dad's 4HP Taylor Compound is a 19' boat and will do about 6.5 knots at best. Throttle it down to 1/2 engine speed and it does about 5.5 knots, so the power has little relevance to the top end speed of the boat. Twice as much power past hull speed will make little difference. The only way to go much faster is to have much more power which I'm sure is not the type of boat you are after.
The boiler like I said before is the part which does the work. The best designs have the most heating surface and the water flowing though the pipes the fastest. No point making steam if it can't get to the top. There are very strict regulations which I would highly recomend you stick to. They are different in America to the UK as well. Saftey must be at the top of the list when it comes to steam. 50 gallons of water at 200C (390F) lands on you, you won't feel a thing. Never mind a burn, the force is enough to obliterate almost anything. Stick to the regulations etc and you should have no disasters.
Boat hulls can and do come in all shapes and sizes. I've noticed a general trend to steamboats are they are made somewhat stronger than the average sail boat or barge. Must be the 1/2 tonne of metal in the middle of them. You should keep this in mind when building the boat (as I'm sure you would). The traditional boats tend to have 2 large bearers running most of the way along for the boiler and engine to lay on. With a 15' boat the length may be much smaller but the wood tends to stay the same thickness, so you would probably get away without having the equivelant of a girder in the bottom. The three main points of interest though are the boiler mount, engine mount and the thrust block. These three parts will put the most stress on the hull. However unless you are going to fit a huge Uniflow and boiler into a tiny little boat with a large 5-blade prop (you'd have to be a nutter to do that! And even more of one to go out with him) I shouldn't have thought the stresses would be all that much.
The great thing about steam is you can do the same thing using 10 different methods. If you were to ask 5 steamboaters a question you'll get 6 different answers, and the perfect boat would have 5 bows and one stern. The levels of complexity are infinate, and you'll have to try and choose one. The simplest also has the ability to be complex so again there is no real answer.
One of the more simple ways would be an engine, boiler, exhaust up the funnel and pumps in water from the lake. Going the other end of the scale possible on a launch (which would be my method, but I like to be different) would be a collection of heat exchangers to put back as much heat into both the air and water into the boiler as you can get away with, pumps galore, electronic controlled oil fired auto-start boiler with variable flame size etc etc. Not a system for the faint hearted, but its possible.
You just have to remember that anything can be done with steam. To get the ecconomy you must use the Enthalpy it contains, but it does work without. Its all a matter of Physics and maths at the end of the day (Physics is Maths with pictures). And most of it is very simple maths. You can even ignore the maths completely and just go for what feels right. I wouldn't do it myself but I recon I am in the very minority on my idea of a perfect steamboat.
I try and think of the steam engine principle as being a system with only 1 limiting factor, and that factor wants to be the controlling factor, like the throttle or valves. Everything else should be large enough to cope with the capacity plus a bit extra. Otherwise you wouldn't be betting the best out of the engine. Steam powered boats all tend to use old technology and old type thining on engineering problems, but I try and think if its better to use modern materials and include some new technology into it (even better if its cheaper) then why not use them? It may not look traditional, but that doesn't bother me. I've made a steam siren out of a explosion proof loud speaker. It looks pig ugly being dicast aluminium painted bright red, but it should work really well.
_________________
Back to top
Alphawolf45
Posted: Fri Jan 11, 2008 8:20 am Post subject:
That boat pictured on top of thepage of this forum--- what can you tell us about it?
Offhand I'd guess that it would be a nuisance to see over the 'hood' on that thing.....but it'd block some overspray..Reckon How long is that boat and what size engine is required to move it along at a good pace?.Is a boat that size trailerable, can it be put in at ordinary boat ramp?..real noob aint I? Hehhehheh
I got some age on me and a lots of wear and tear, I looking to do a few 'bigger' things while I still can..On my possibles list I thinking I might enjoy building a boat and running it 2000 plus miles down the Mississippi or some other long river......and while I not now trying to build a boat capable of comfortably doing long trip like that , it is in back of my mind.
So I wonder about issues like speed/ how many miles can easily be covered in an 8 hour day,, and fuel milage? and will I need to carry lot of extra water for the engine..
What does a boat have to guage knots? Pounds of steam used per hour?
Back to top
Maltelec
Site Admin
Posted: Fri Jan 11, 2008 1:20 pm Post subject:
Unless you are on sea water or really dirty water, you can simply take the water from the river. The mudier it is the more often you should blow down.
I've known a comment from a busy body who said he can tell the boat was breaking the speed limit because of how much wash it was making. This is of course utter nonesense.
You need a log or GPS for a real measurement, though engine rpm will give you a rough guide.
A resaonable engine, say about 6HP may use around 600lb per hour. If you get an SBA register you can look and see what boats use what engine and boiler sizes. Obviously the bigger the better but that isn't always practical.
Its called Elpenor. Its got a Website Here. It uses a large uniflow and boiler and the hull is plywood. Its certainly trailerable and appart from needing a larger vehicle to tow it up the steep hill out of the Motorboat Club at Windermere it can be and is towed with a normal family car. Its owned by David Ayres who has built it all.
The hull may not be "traditional" but its quite stable and certainly goes well. Its one of the few boats of its size which I can't keep up with on my dads boat.
Fuel consumption depends a lot on what you are doing. On the lakes over here you tend to use a lot as you go flat out all the time, but on the canals you may only do 4mph instead of 6 knots, but you use 1/2 the fuel.
As for being a N00b, you should get yourself over to the Windermere Steamboat Rally in August. Its usually entertaining with many boats and plenty of rain. There are some pictures in the Rally Reports pages on here of ones I took.
_________________
Back to top
Edward
Posted: Fri Jan 11, 2008 3:11 pm Post subject:
Hello Steven,
Although I agree in principle with everything Maltelec has written above I have a couple of observations/comments to make/add:
1) Steam consumption of 600lbs per hour should drive a stonking big
engine by the standards of a 15'-20' small steam launch . 200-300 lbs
per hour should be adequate, though I agree it's reassuring to have
something in reserve ; trouble is "reserve" in this case means a bigger,
heavier (more on this later) and therefore more expensive boiler.
2) Hull speed. Roughly speaking the maximum speed a displacement as
opposed to a planing hull (with only 1 or 2 exceptions ALL steamboats
are and always have been displacement hulls) is equal to the square
root of the waterline length X 1.2. This assumes a nice hydrodynamic
smooth hull shape and not too much weight. Weight is important
as it increases the displacement and means you have to push more
water out of the way; so perhaps Maltelec should have written that f
two similar shaped hulls , given the same power to weight ratio, the
longer one will be faster or will require less power to reach the same
speed.
He is absolutely right in writing that the art is in getting the balance
of boiler size, engine size, hull and prop right. Inevitably it's a compromize and you only have to look at the approaches different owners/builders have adopted to see that there are are many ways to achieve one's dream.
As a newcomer to the hobby I absolutely recommend attending as many steam boat events as you can to see what other people have done . One of the difficulties is that if you ask 3 people what the answer to a particular problem is you'll get 5 different answers (probably all workable !)
Back to top
Alphawolf45
Posted: Sat Jan 12, 2008 6:16 am Post subject:
Edward
I taking next couple months to study books and what I can find of the internet and then will finalize decisions and start building. It will suit me fine,once I begin I doubt I have to ask anybody for help solving a problem of any magnitude.
What happens when the average 15- 25 foot steam boat capsizes? The pictures of boats I am seeing appears that the engine and boiler are proportionally heavy as compared to the bouyancy of the hull materials....So I thinking that if motoring along in high seas or whitecaps and wave crashs over the bow then odds are good that boat will go straight to the bottom ?
32 years ago I took a 18 foot long 7 foot wide flatbottom aluminum outboard out on river with 3 and 4 foot whitecaps and swells to rescue 4 persons from a capsized catamaran sail boat.....It was 2 men and two very fat women each weighing- I am guessing each weighed more than 300 pounds, possibly lot more than that, real blubbery gals...I got one of the guys into the boat with me and together we struggled to pull the fat gals into the boat..Then with everybody in the boat we headed back across the river, were too heavy, riding too low in the water, weight wasnt distributed right, a big wave come up in front of the boat and boat just plowed right into it. One moment I was sitting down and next moment we were all treading water.....fortunately was by then within 50 yards of shore and all folks made it on in....My boat sank engine down on the Illinois river bottom and bow in the air floating because of foam flotation under the seats. Was not difficult for next boat coming out to hook a rope on it and tow it to shore.....
Back to top
Alphawolf45
Posted: Sat Jan 12, 2008 6:27 am Post subject:
Maltelec
OHHHHHH I like that motor on that boat...That just about exactly what I had sketched out and was looking for drawings of..Purty,purty,purty,purty
Back to top
Maltelec
Site Admin
Posted: Sat Jan 12, 2008 11:08 am Post subject:
I've got several video's of engines on my Youtube account.
This is one of them:
http://www.youtube.com/watch?v=F7ALRmgiW3w
If you like Elpenor's engine you should e-mail David and ask him about it.
_________________
Back to top
Edward
Posted: Sat Jan 12, 2008 11:42 am Post subject:
[quote]What happens when the average....steam boat capsizes?
Dear Alphawolf45 ,
I can't speak of steamboats in the USA, but if the average UK steam boat capsizes it sinks. The vast majority of UK steamboating takes place on reasonably sheltered inland waterways and lakes. None of the rivers are particularly deep, I'm guessing but I'd say that 15' would be a deep river though obviously there are deeper places; canals are pretty shallow, you'd be lucky to find 6',3' is more common; lakes and the Scottish lochs are much deeper, Windermere about 120' and I believe parts of Lochness are several hundred feet deep. So in the majority of places salvage/recovery is not a huge problem, in some it would be a nightmare.
Personal safety of course is another problem as if incapacitated an adult can drown in only inches , as can a small child even if not incapacitated. So it's sensible to have self inflating life jackets of some sort and cushions filled with buoyant foam.
I'm probably stating the obvious in saying that one should be aware of local conditions and weather forecasts and the capabilities of one's boat and never go out if in doubt.
Given the conditions in which most UK steam boats operate they are not designed for rough conditions, though most would probably be safe beyond the courage of their crews.
It is possible to design in buoyancy, but a steam engine and boiler are heavy . Typically the plant for a 15'-20' boat is going to weigh between 280-800 lbs, so to be on the safe side you need to plan-in between approximately 5-15 cubic feet of buoyancy just for the plant. In an open boat compartmentalization is desirable but can obviously only extend up to a limited extent.
So to summarize: most UK steam boats would sink if they capsized; it is possible to design-in buoancy but user common sense in only using your boat within the conditions for which it was designed is PARAMOUNT
I must stress that I am neither an engineer nor boat designer, but I believe that what I have written in answer to your question is correct.
All the best, Edward
Back to top
Maltelec
Site Admin
Posted: Sat Jan 12, 2008 1:46 pm Post subject:
I suspect many boats are like trains, where the major parts are only held in place due to gravity.
I know for certan on my dads boat the boiler is located on some pins and nothing else. If the boat was to tip upside down the only thing to prevent it from falling out is the fact that the pipework is attached to the engine, which is firmly bolted down.
However I should imagine if you are already in the position where the boiler is falling out of the boat, the boiler would be the least of your worries.
I seem to remember Windermere is around 46 meters deep at its deepest point, 214 feet. Wether the rest of the boat would stay afloat if the boiler broke the pipework and sunk would be another question.
I don't know of any instances where a steamboat has capsised in recent years.
If the weather is too bad on Windermere (it can become very very bad in minutes) we tend to all stay inside and talk nonsense about steam things. I remember being at one end of the lake (10 miles long) and it turned from glorious sunshine to a huge thunderstorm and pitch black within 5 minutes. We saw the wall of cloud comming over the hill. Took us 2 1/2 hours to travel 4 miles back. Couldn't see a thing. Middle of the lake on a boat with a large lump of metal poking through the roof is not the best place to be in a thunder storm.
_________________
Back to top
Alphawolf45
Posted: Sun Jan 13, 2008 10:32 am Post subject:
Can a guy build a steamboat and use it for a season and then sell it and re-coup his invested monies?..
.Is there good market for a welldone homebuilt steamboat?
Whats the thinking on selling a boat with a home shop built boiler?
Would it be better to sell boat without the boiler to limit sellers liability?
Can you get good money for a boat if boiler is not included?
Back to top
Maltelec
Site Admin
Posted: Sun Jan 13, 2008 6:08 pm Post subject:
If you make it as cheap as physically possible, then maybe just about. Thats if you plan on including your time of course. The actual material money you can probably get back, but from a business point of view its a very very small market. I don't think anyone specialises in just steamboats.
I think I've mentioned it before, you displace water in the shape of a hull and fill it with money.
If you are thinking you want to build a toy in your spare time and simply recover your expenses, I recon that is possible. Though you'll be suprised how long it takes to build it. If you pressed on with it, you could build a simple engine in a week. However I am sure you know as well as I do that the gremlins see you are making good progress and will start to pinch all your tools, break things when your not looking and alter the drawings so the thing you've just made to perfection is the wrong size.
.Is there good market for a welldone homebuilt steamboat? - I would say yes deffinetly over in the UK. You tend to find the smaller boats are popular for 1st time boaters and the bigger boats are either built by long-serving steamboaters or bought by people with pots of money.
Whats the thinking on selling a boat with a home shop built boiler? - As long as it meets the legal requirements etc, there shouldn't be a problem. The requirements are quite strict over here. You must have a certificate to weld a boiler, and the design must be approved for a start. Cross the t's and dot the i's. Saftey is always 1st with these things.
Would it be better to sell boat without the boiler to limit sellers liability? - Pass on this one. At the end of the day, better safe than sorry. But if you don't trust the boiler with someone else, you shouldn't have it on a public river/lake yourself.
Can you get good money for a boat if boiler is not included? - Yep. If you see a steamboat complete except for a boiler, all the hard work is done, you just need to aquire a boiler and spend a few days plumbing it in.
Its hard to make money with steamboats, though some people are successful. My interest is in the machinery and using them, the money side doesn't appeal to me except for spending as little as possible (which I fail at most of the time). Saying that I'll spend more on a devent valve than saving a few pence on a chinese ten a penny type. What you spend in the short term you often save in the long run. My thought on any construction job, especially a DIY one is do it to the best you can. The quality shows at the end of the day.
_________________
Back to top
Alphawolf45
Posted: Sun Jan 20, 2008 1:51 pm Post subject: Fuel for the fire
This is one of them subjects that should get some chatter going...I wondering what fuel you guys fire your boilers with and how you decided what to use...
I rather like the idea to use wood but I suspect that the reality of cutting and splitting ,stacking and drying wood isnt a chore I would get a lot of satisfaction from doing with any regularity...I need to check for availability of other fuels.
Coal is an option..Waste vegetable oil is an option..What others? Kerosene? Is diesel fuel used by anybody?
Comments on multifuel boilers?
Maltelec
Site Admin
Posted: Sun Jan 20, 2008 6:06 pm Post subject:
If it burns, use it
We did run ours on coal but we are in the middle of converting it to Parafin.
Some burn diesel, I don't think theres any reason why you can't use petrol or waste oil (other than the smell).
There are the odd few people who use only wood. They say the harder woods burn with more heat.
I recon I'd use Parafin on my boat if I ever finnish designing it. Vapourising burner with electronic pressure control.
Many people use 240v burners like you have on central heating wnd run them off an inverter. This works fine but you find the burner is constantly stopping and starting as they have no real turn-down ability.
My idea would be to use feedback from the pressure and also use a forced draft. The forced draft would most probably be controlled by the oil valve. The oil valve would be controled by the pressure of the boiler. I've got it all designed in my head and the electronics part is very simple in principle.
The key factors I am aiming for are:
Quietness
Userbility (i.e. made so a monkey can drive it, we called him Dad)
Reliability - being British it must break down at least once a day but with the ability to ignore it and keep on going
Automatic - You can leave it to run all day and night and it'll ensure the water level and pressure is always within tolorance. With the engine's electronic valve timing I can also use it as a govoner.
Theres no limit to the designs and methods which can be used. The more complicated they get they become more like a floating test rig.
But theres nothing wrong with the simple coal shovel.
The only thing I've noticed is the simple methods tend to adapt scrap parts (like car prop shafts) and alter the plant to fit the prop shaft etc, where the complicated ones have everything made to fit the plant.
_________________
Back to top
Alphawolf45
Posted: Sun Jan 20, 2008 8:11 pm Post subject:
.Yes thats funny and so true.. I am generally in favor of scrounging parts and fitting together whats on hand but it takes a keen understanding of the requirements for the application..I have good supply of junk so that a clever mechanic could construct most of a functional engine without needing to go outside for supplies...But given my inexperience , I am about embarassed to admit this -- I may have to buy a set of plans and mostly follow'em..
I looked this up on the net and read that hardwood charcoal gives 13,440 btu s/pound...Thats good heat and the material is easy to get- widely available- at reasonable price..I might go that route...
Back to top
marinesteam
Posted: Mon Jan 21, 2008 11:31 am Post subject:
In the US you have a lot of options for fuel. The tradeoffs are ease of storage and transport, amount of preperation needed before use, cost of fuel, cleanliness, availability and ease of use.
I have been looking at fuel choice and have a few ideas as to what I will pursue to fit my criteria. I'll list a few of the fuels and you can look into how they may fit with your needs.
Kerosene: (Paraffin to the UK(I believe?) is readily available here in the US in 5 gal pails from home improvement stores. Has the same benefits and drawbacks as diesel. Some smell, spills and needs a vaporizing burner.
Wood pellets: Available at home improvement stores, clean and easy to handle, Lightweight pellets will pull off of grate with strong draft and may be pulled up the stack before fully burning, Special grates required as they are small and will fall through bar grates. My be able to be fed with a stoker system (auger or steam jet).
Charcoal briquette (ie Kingsford): Most like coal and easily available. May have high cost and are a bit dirty to handle.
Wood pellets are at the top of my list with charcoal briquettes second.
I'd like to hear some comments from those who have tried these fuels.
Also, there has been mention of Lune Valley type boilers being used with solid fuel. Can anyone tell me where I might find plans or design guidelines for this style boiler and how it changes with solid fuel. I intend on having the pressure vessel design checked and welded by an ASME S stamp shop.
Back to top
Alphawolf45
Posted: Mon Jan 21, 2008 11:10 pm Post subject:
Marinesteam
A man suggested to me that I consider using corn as fuel.I know nothing about that but that it sounds like a possible option.I leaning in favor of hardwood charcoal..
Are You building a York compound from a set of castings?
Back to top
Edward
Posted: Tue Jan 22, 2008 4:57 am Post subject:
As I've written before I'm no expert and am no sort of an engineer , but I think there are some aspects you've all ignored. Perhaps they're so obvious that you felt they didn't bear repeating ; but here are my comments:
A boiler will work best burning what it was designed to burn. If designed for a fuel of low calorific value it will need to have a larger heating area and vice-versa. This is particularly true for fire-tube boilers; I believe some agricultural and portable engines were built for the South American market to burn straw, they had HUGE fire boxes and a conveyor belt to feed the straw into the firebox. So by all means "if it burns use it" but be aware that the lower the calorific value the more fuel and bigger heating area you'll need. So a fire-tube boiler designed to burn coal won't produce much steam if burning wood however if designed for wood but burning coal it should steam like a demon!
Storage space can be a consideration, especially on a small boat. Liquid fuels can be squeezed in just about anywhere in flexible or custom built tanks, coal and wood can't and with wood you're going to have to carry quite a lot.
Liquid fuels are probably going to need some sort of electrics to provide forced air. Even a steam atomizing system will need something to get it going before you raise enough steam for it to be self sustaining, if you're running on salt water you will have to carry a lot of make-up water for it. Other vapourizing systems may not need electrics but can be noisy.
In the UK all boats are subject to periodic safety inspections. These are pretty straightforward for solid fuel boats, slightly less so if you have liquid fuel and batteries. But they're easy enough if the system has been designed and installed to conform with the rules.
So yet again there is no single simple answer, it's a question of what's available and what you like, But you do need to decide what you want fairly early on in the planning/aquisition process and act accordingly.
Back to top
marinesteam
Posted: Tue Jan 22, 2008 2:16 pm Post subject:
I do have a set of York castings.
It seems that I am not so much building a York engine as just owning a box of misc. metal bits as I haven't made much progress recently.
I'm kidding to some extent as I have made some progress, I just haven't done any machining yet.
I have been preparing the castings for machining. Getting rid of the parting lines and flash, also I intend on polishing all of the bronze to a bright finish so I have been doing a lot of sanding to smooth the sand cast finish. It's time consuming work and has been a bit of a learning process figuring out which tools work the best. So far I have found that die grinders and various abrasives (flap wheels and rolls) have been the most efficient due to the curviness of the parts. I did go a bit overboard and brought one of the parts to the final bright finish just to see the whole process at one time and the polished bronze looks really nice. If you take time with the initial steps the later steps go quite quickly.
If you are considering the York engine I would become a member of the SBA and get the back issues of the Funnel that cover Paul Eaton's articles on his build of a York compound.
If you are looking for a quick project that can get you steaming and on the water don't overlook a Themes style steam canoe. They look like fun small boats that can go a lot of places and are relatively easy to handle from a build and operational stand point.
Back to top
preaton
Posted: Wed Jan 23, 2008 2:25 am Post subject:
Ken, Good luck with your build.
Happy to answer questions if you have any.
At the end of the day like any big project, you just have to bite the bullet and start. It doesn't get easier thinking about it. I'm just an ordinary guy with no machining experience. I've now got a big beautiful York compound waiting for me to finish the hull. Maybe, maybe, maybe by Christmas 2008 I'll have me a steam boat.
Paul Eaton
Back to top
marinesteam
Posted: Wed Jan 23, 2008 1:30 pm Post subject:
Paul it's good to hear that your part of the forum.
Thanks for the support.
I have just up sized my lathe from a 9x20 to a 12x36 for this project and plan on purchasing some of the stock for the valve gear parts this week. Hopefully this will get me out into the shop making some chips.
How is your hull coming along? Any chance that you could post some pics of the engine and hull for the group?
Thanks
Back to top
Maltelec
Site Admin
Posted: Wed Jan 23, 2008 5:45 pm Post subject:
You'll find once the boat is "finnished" you'll take it appart again and redo it with all the problems fixed.
Then the same next year, and the year after ......
Thus a steamboat is never finnished, it just has different states of working and non-working.
_________________
Back to top
Alphawolf45
Posted: Sat Jan 26, 2008 9:38 am Post subject:
marinesteam wrote:
I
marinesteam
Castings and/or evidence of castings is much preferable to building from barstock. You are king in your own workshop can work to suit yourself ..I do lots of metalscasting ..I might machine away all evidence of casting if I did crappy casting but usually a sand cast surface is a handsome appearance that I try hard to preserve..
What is a Themes style canoe.?
I am not so keen on compound engines after reading that they require higher pressure steam that a simple engine....Much to consider.
Steven
Edited for errors in spelling.
Back to top
marinesteam
Posted: Sat Jan 26, 2008 9:50 pm Post subject:
Look here for an example
http://www.storerboatplans.com/Steam/Steam_Canoe.html
There are a bunch of steam powered canoes in the SBA and pictures will show up on occasion in the Funnel. This style of canoe actually looks to be quite large and capable of carrying three or four passengers. If your not a member of the SBA, I would really suggest becoming one. The Funnel is a great resource for all aspects of steam boating and the trip reports can be especially entertaining.
I decided to finish the bronze castings of the York engine bright as I prefer the refined and polished look. There is no mistaking that these are castings as they are quite complex and curvy, I think the reflection from the polished surface enhances the shapes of the pieces. Just takes a lot of work to get 'em shiny.
It's been argued that the size engines that are found in small launches are too small to effectively utilize the efficiencies gained by compounding. I'll leave that subject to members of the group that have more experience than I. I picked the York because it is a traditional looking engine and as a compound it has more moving bits to watch when it turns than a single cylinder engine does.
Back to top
Maltelec
Site Admin
Posted: Sun Jan 27, 2008 5:21 am Post subject:
Although I suspect this is true, and you're never going to get the efficiency above 5% or so, it looks good which is what it is about.
_________________
Back to top
Maltelec
Site Admin
Posted: Sun Jan 27, 2008 3:41 pm Post subject:
Just a note that I've moved this topic to the General Steamboat section as it is more relevant here.
_________________
Back to top
P.F.Cuthbert@Classicfm.ne
Posted: Sat Jan 31, 2009 3:31 pm Post subject:
Just a few observations in case they may help:
1. You sound more like an engineer than a boat builder, so why not acquire a second hand steamboat/displacement hull and fit it out. In the UK these do come on the market, and I would expect that the US has a similar market.
2. Fuels in the UK generally include kerosene (very difficult to buy these days), diesel, coal and even bottled gas. Welsh Steam Coal was the Gold Standard, and some supplies are still available, but most folks have to use lesser quality imported stuff. Gas is a minority interest as it is surrounded by a sheaf of regulations. My US/Canada contacts tell me that wood is very big as a boat fuel there. Preferably hardwood, and nice straight thinly sliced air dried oak is ideal I am told. In the UK a few boats have adopted diesel fuel (easy to buy if not that cheap) and in some cases waste cooking oil.
3. Your boiler design is probably going to dictate your fuel. Wood needs a large combustion space whereas coal and oil will work in a smaller space. Liquid fuel bring the problems of all the machinery to make it vapourise and burn - ie. fans and such, all of which is likely to mean you need an electricity supply. That means batteries and yet more weight.
However, if you can put up with that, it is possible to buy diesel/heating oil burners "off the shelf"...
So, the choice of boiler is not an easy one. It needs to be big enough to supply you engine without constant forcing. After that it is a case of funds and aesthetics. Myself, I like the Blackstaff Wood design as it looks the part and has a low centre of gravity. Whether that has been a sensible choice will not emerge until I can get it built and tested!
Good luck.
