If you find your user name and password don't let you log on to the forum, have you tried the following:
1. Have you registered on the new forum? I couldn't copy across the membership database so everyone will have to register on this forum.
2. If you have registered, are you using the correct URL (address after the http:// bit)?
If you see: http://80.82.121.119/forum in your address bar, this is wrong and will cause login problems. Instead, please use: http://www.thesteamboatingforum.net/forum
Can't log onto the forum?
- Maltelec
- Master of the Forum
