Well it's Dec 1st I had the boat out on Nov28th there's a full moon and a clear sky-That's means only one thing-It's gonna freeze!! Those of you in the great white north -are you ready? Those of you in south America like Ron ,Wes and Bart need not worry I had about 10 lb pressure left in the boiler so I blew it down.That did two things,it cleaned all the crud out of the mud drums and it allowed the boiler to dry inside.Then I unscrewed the plugs in the muddrums and replaced them with plugs with holes drilled in them [that allows air movement and no mice wandering into the boiler] I disconnected all the lines to the hot well ,boiler feed pump,air pump. My boiler feed pump,air pump and keel condenser all have drains in them-I removed them. Then I pulled the heads ,wiped the cylinders down and sprayed liberal amounts of WD40 in the cylinders,steam chests,and on the pistons making sure to get the rings. I spun the engine over to get the full cylinder. OK light bulb in the boiler and She's ready for a snooze! Did I miss anything? Oh yeah I drained my spare water tanks! This is mainly for the newcomers-Don't get caught. They're calling for snow next week! Bundle up Den
Well, I ride my bicycle to work year around down here in "south America" , but since it's down into the 40s by the time I go home this time of year I wear some warm clothes... it does freeze here once in a while, but never really a hard freeze. Once or twice I've seen forecasts for high twenties, so I put a bulb under the canopy just in case... but friends who live in the surrounding hills do need to watch out for frost. I guess if you had a boat on the water in the San Juans all year (say in Fisherman's Bay on Lopez Island), you'd need to be able to drain the boiler into a rubber bladder tank (freeze proof), since it can get pretty cold even on the water during a Northeaster....
I take pictures of the plumbing for documentation...
Then,
I take off all the plumbing and fill the boiler with antifreeze. Neutral PH.
No air and neutral PH will reduce the corrosion.. Leave a bit of air in a nipple above the dome at the top to allow for expansion and contraction.
Antifreeze good to -30F minumum
I take the engine out and the condenser off. Those and the plumbing go indoors. I drain the main tank and all the remaining plumbing.
Then two sets of tarps on poles to shed the snow.
We can get to -20F pretty easy in January...had a major (worst in 50 years) ice storm about a year ago.....4 days without power...My friend in NH was 14 days..
"Up here" at 6500 ft elevation we get tons of snow... I winterized my boat back at the end of September, we've had plenty of below freezing days since then... not much snow as of yet; only a couple 4-6" storms, including one last Friday. We usually get a good 2-3' storm around Christmas and plenty of "multi-footers" 'till April...
Steamboats don't come out of hibernation until after Memorial Day... and even that's risky sometimes; Snow on June 6th the past coupe years.. We've had snow on 4th of July in recent memory... Global warming
I guess you could say we're the "Siberia" of California
Here in England we are getting the first frosts, but generally it is not that cold (5 to 8 degrees C). Working in the garage is still possible without backup heating. However, I spent a couple of hours sticking some of the "fancy" work with thickened epoxy. Come the next day is was still sticky - oops! Must remember to read the epoxy instructions...!
(Another Thought - must do a photo to show you where this ham fisted amateur works...)
Reading some old posts and thought I'd add one small idea.
I use my wet or dry vacuum cleaner to clean out all of my piping after blowing down and draining the hot well. Opened up a few check valves and my Hypro feed water pump just for insurance and there was no water in them. Hope the keel cooler got emptied!
I know you were trying to be funny Mike,but yes I did take the plugs out of the keel cooler .But when I went to launch the boat the next Spring I suddenly had a terrible thought as I backed down the boat launch ramp-so I stopped -yup sure enough I forgot to put the plugs in!!! So when you make a list ,make sure to reverse the process in the Spring! We wouldn't want Mike to get the last laugh!! Den
Well, that won't be a problem for me as there aren't any drain plugs in my cooler. It's far too crude for that.
What could happen is sort of related. I have a drain at the low point in the hull to deal with any rain water getting in while the boat is on the trailer. It's only a small plug but it would add to the usual fire drill when launching.
The dock at my local ramp is maybe twenty feet from the ramp so I get the pressure up to 50 or so before I back down so I can steam over to tie up. What with fussing with one thing and another I can see myself staring at the bilge and wondering what the heck is going on!!
