I modeled the entire modified 6A in Solidworks before starting any machining.
Further CAD images here:
https://www.facebook.com/pg/steam.launc ... 0141114538
Here is a link to the Lubricator for my 6A. The lubricator design is loosely based on a design by Alex Ritchie that uses Interlube mini pumps, but is a total rework. My lubricator has a two compartment tank enabling the use of cylinder oil and bearing oil within the one unit. One pump is used for cylinder oil and nine pumps are used for main, big end, little end, and cross head bearings.
There are many pictures of my engine build on my Facebook page and can be found in the Albums, I have had too spread the build across a number of albums because loading gets to slow using a single album. please see the link below for the lubricator album. I will be continually adding to the 6A build albums, the engine is almost finished and I have hundreds of photos of the build.
https://www.facebook.com/pg/steam.launc ... 5684454317
cheers
Lionel
