I am in the early stages of building a 22' steam launch, with hull built via the cedar strip plant method. Having built several boats in the past, I was tolerably confident, but had never used the strip-plank method, and so decided to make an 18' canoe first, starting from buying wet, as imported, lumber. If it went horribly wrong, then never mind, it's not that big a deal, and the same philosophy allowed me to experiment with all sorts of things while building - most being successful, but some needing a bit of work to undo.
Anyway, you can see the canoe results below: she takes two largish adults and a labrador-cross dog comfortably. Part of the experimentation was to buy a remarkably cheap 400-Watt electric outboard, to run off 12V 85Ah electric fencing batteries, of which we have several for electrified sheep netting. This turned out well: she does 4 knots at full power, and one battery lasts over half a day - not a steam plant I know, but just as quiet, and certainly not an infernal combustion engine.
Moulds on a strongback in my 17th Century barn/ workshop
Planking almost finished. Marine-rated polyurethane glue makes an awful mess where it squeezes out of the joints, but it sands off very easily - on the outside of the hull anyway.
Hull turned the right way up for the first time, with epoxy glass covering on the outside, and untrimmed, but nothing on the inside yet.
Splicing (scarfing) gunwales and inwales from ash. Too long to get inside the workshop.
The completed canoe on trestles.
Another shot in the same spot.
