Posted on behalf of marinesteam:
marinesteam
Posted: Fri Jan 16, 2009 3:54 pm Post subject: York engine builders - Question on material selection
I was getting ready to buy some more material for my York engine build and ran into a little snag that I can hope someone can help with.
Part PC27-B which are the HP & LP valve stem gland nuts are spec'd as brass. I am wondering if I can substitute bronze for these parts. I don't see any function reason that bronze couldn't be substituted, but wanted to see if anyone has an opinion.
The reason I'm asking is that when I looked to buy the brass from my favorite metals houses I can either: buy a six foot bar at $38 / foot or a one foot bar at $90 / foot (diiferent suppliers). Since I only need 4 inches, I feel real bad about buying six feet and feel like I'm getting screwed buying the foot at $90. I have a friend who has some bronze drop offs in the right size but don't want to create some unintended problem by unintentionally substituting the wrong material.
Thanks
Colorado, USA
Back to top
Froya66
Posted: Sat Jan 17, 2009 10:36 am Post subject:
Hi Ken
I am not extremely experienced, but I have made a few nut from brass as well as bronce.
If I happen to have a piece of bronce that fit the size of nut I want to make, I prefer to use that.
The bronce is a litle stronger and more ductile than the brass.
I believe that brass is normally used for nuts due to the smaller cupper content, and thereby a lower price.
Best regards
Jørgen Hansen
Esbjerg Denmark
Back to top
preaton
Posted: Thu Jan 22, 2009 12:58 am Post subject:
I used LG2 bronze. Easy machining and stronger than brass. For a real engine (as opposed to a model engine) bronze is the way to go.
Good luck
Paul
Back to top
P.F.Cuthbert@Classicfm.ne
Posted: Sat Jan 31, 2009 2:55 pm Post subject:
Dear Ken
Having just read you query it called to mind a comment somebody made recently about nuts in hot places (if you see what I mean).
Could it be that the nut is specified as brass rather than steel simply to make it easier to remove after it has been subject to some time at high temperature and humidity? The immediate similarity that springs to mind are the exhaust manifold nut on automobiles. I believe that they were brass rather than steel to facilitate removal. (Mind you, I have barely opened the bonnet of a car for 20 years so have no idea what they are made of now!)
Best wishes
Moderator: csonics
