Posted on behalf of Doug B:
Doug B
Posted: Fri Apr 11, 2008 10:56 am Post subject: How much make-up water ?
How many gallons should I make my make-up tank in my steamboat?
I have a 2.5" X 3.75" X 2" fore and aft compound running at about 400 rpm. Its a condensing system with feedwater pump. hotwell, etc.
I'll be steaming at about 125 to 135 psi.
Any ideas or suggestions would be a lot of help.
Thanks, Doug B
Back to top
Posted: Sun Apr 20, 2008 8:40 am Post subject: How much make-up water?
Doug
I have 30 gal available to me which gives me at least 10 hr steaming.On longer voyages I carry a collapsible 5 gal water container[heavy plastic bag really] It's handy for making tea or washing dishes as well! There is an old adage-"what will do more will do less"- and would rather come home with extra water than run out! I run in the ocean but if you plan to run in fresh water you have an unlimited supply just overboard ! Den
Back to top
Doug B
Posted: Mon Apr 21, 2008 7:44 pm Post subject:
Hi Den,
Thanks for the info. I just epoxied my water tight bulkhead into the bow. It's an intergrel tank and holds about 15 gallons. It's vee shaped, 28 inches wide and 22" high at the bulkhead. It's 28 inches long, bulkhead to the bow.
Do I need some baffles in the tank?
I've seen your name on the NWSS bulletin board. Do have a boat here in the Pacific Northwest?
Thanks again for your ideas,
Doug B
Back to top
Posted: Wed Apr 23, 2008 7:07 pm Post subject: make up water
Doug Probably not -But the water level is low it might slosh out the vent and leak sooo-nows a good time to do it!! Take a look else where in this forum I have submitted some pictures Den
Moderator: csonics
