Knowing that stainless steel is not being accepted in Anglo-Saxon countries for the manufacturing of heated pressure vessels, I thought it would be interesting for you to know that stainless boilers can get the necessary certification in Europe, provided a series of requirements are satisfied. As far as I know, several boats with stainless boilers are being operated in Germany, and at least one in France.
I started the process by preparing a sketch with the desired layout. My initial strength calculations had to be confirmed, and the final drawings made by a specialist prior to submiting the project for approval.
By trying to save the inner and outer boiler hoods of a previous boiler, I shooted myself in the foot... Otherwise, the boiler could have had a larger heating surface.
The work was carried out in a certified workshop, the process being supervised by the TÜV (German Technical Inspection Agency).
Here is the sketch of the desired layout:
Cut to length and prepared for welding: 151 tubes 25 x 1.5 mm
One of the two tube plates, laser cut, waiting to be bevelled:
Components put together:
Ready for welding:
The shell, laser cut, rolled and welded:
