- Provide an ample sized keep condenser. For my (so far theoretical) big boat this would be sufficient to cool 300 lbs steam/hr from 170F to about 60F, a few degrees above water temp.
- Pull the water out of the keel condenser with an air pump at 60F and then run it through a feed water heater in the exhaust stream. Since the vast majority of the energy is the change of vapor to liquid, the exhaust will stay essentially at 170F and heat that cold water right back up to nearly that temperature.
So long as the exhaust temperature doesn't reach too high, this will work w/o any moving parts. If the engine exhausts at above 200 F for any length of time. some sort of temperature control will be needed; a simple 180F automotive thermostat can clearly be used for this purpose.
The neat thing is this lets us bolt a nice shiny brass/copper heat exchanger on the engine w/o the need for additional pumps, risk of flooding, etc. that a raw water cooling system raises on the inside of the boat. And the hot well is always the right temperature, regardless of the outside water temperature.
Just make the keel condenser big enough.
