An earlier picture showed the drum stays protruding through the end plates and retained with dome nuts. As mentioned, a drawing popped through the email from John King suggesting an improved arrangement using sleeve nuts with low profile hexes. They are aluminium bronze to resist corrosion and have a longer thread to compensate for the weaker material. They will be sealed with dowty washers. This arrangement will give more clearance for fittings on the drum end, which can be a bit tight on this type of boiler. It is rather a rolls royce upgrade - the material cost was £120 for the 12 nuts. But it will look good.
An ebay seller made up a rolled alloy tube to form the outer funnel. The joint is not “joggled” as I had ideally hoped, but will just overlap. The outer will be spaced out from the stainles flue pipe inner by bolts and spacers. A brass band at the top will be nice.
Most builders will fabricate the fire door, but I have started patternmaking for a door and surround to be cast in iron.
Door frame with hinges on the port side and keeper on the starboard.
Door outside
Door inside with bosses for heat deflector bolts. The perimeter has a thickening , which will be grooved for a fabric seal.
John
