http://www.storrick.cnc.net/VerticalDev ... Icons.html
If you try to make something idiot-proof; nature will just provide you with a better idiot!
I don't know where you draw the line between virtually running out of one resource and actually running out. I know that the switch to coal often involved the accompanying increased human casualties from mining accidents. That seems less virtual to me.RGSP wrote:In fact England, Scotland and Wales (I don't know about Ireland) never ever ran out of firewood: the stuff was harvested from short rotation coppices, and iron foundries etc. had vast areas of these, run on an entirely sustainable basis. However, the harvesting and transporting of such wood was expensive (as CB well knows now with Nyitra) and coal was both cheaper and in many cases easier to use. The usage cost of wood was the driver for more coal mining, and the better energy density of coal. English woodlands were and are, almost entirely hardwoods, which in turn are almost impossible to kill by cutting them down - unlike most conifers - and cutting them just stimulates faster growth next year, though they do have to be protected from browsing animals for a year or maybe two.
I never realised how much you are burning. I am one of the few wood burners over in the UK. My plant consists of a SBA WTB1 boiler which is the smallest water tube in the range, but still with a grate around 16 inches by 10. 100psi. A ST 5a engine 2.25x2.25 single. And the hull is plywood 17foot 10 inch. I have never weighted how much wood I use in a days steaming but can not be more than 50- 80 lbs.cyberbadger wrote:Well the aquisition, processing, and transportation of solid fuel has become a big chore. 300lbs for 4 hrs voyage took me 2-3 hrs to process+ and get on the boat.RGSP wrote:It's your choice Mr C-B, but are you really worried about efficiency in your steam related activities?
It has made me appreciate first hand why the world switched to liquid fuel.
I think your countrymen had a problem with this a few centuries ago running out of trees to chop down...
When I started this enterprise, I didn't know I would have to be a plumber/fitter. It's obvious, but I underestimated. Now I realize I have to be a lumberjack.
Fascinating. Thanks for mentioning this; I've learned several new things today in further reading.RGSP wrote:You should read Oliver Rackham on that topic (sadly, he's now permanently in the crypt of Corpus Christi chapel, as of two years ago). Oliver was a brilliant man in a quiet sort of way, and a superb ecologist, and he (quite rightly) had this thing about factoids.cyberbadger wrote:
He defined a factoid as something that somebody had claimed, then after 25 years it was quoted by an historian, and in another 25 years or whatever, a second historian quoted the first one. By that time the original "thing" was accepted by the unthinking majority as fact, regardless of whether it actually made sense when you investigated it thoroughly.
Well. I knew going in that the Toledo would be a steam hog. It might help to make replacement piston valves. You reap what you sow I guess. The new nozzle allows the boiler to keep up and operate 150-200psi which is great - but I have so much heat going up and out that is not being captured. At least wood is free/cheap other then time.Mike Cole wrote:I never realised how much you are burning. I am one of the few wood burners over in the UK. My plant consists of a SBA WTB1 boiler which is the smallest water tube in the range, but still with a grate around 16 inches by 10. 100psi. A ST 5a engine 2.25x2.25 single. And the hull is plywood 17foot 10 inch. I have never weighted how much wood I use in a days steaming but can not be more than 50- 80 lbs.
Fair enough.fredrosse wrote:I don't know, but I think Penberthy literature just might be trying to promote Penberthy injectors?? That would not be the first time that advertisements show strong bias toward their profit motives rather than logical thought. For example, some famous cigarette ads promoting smoking, as recommended by a DOCTOR, WTF!
Are you over firing? I use two types of wood . my main fuel, logs as big as i can fit say 3inch dia and then some much thinner wood. My boiler is problerly too big for the engine but i try to only add fuel when the presssure drops. if i leave it too much i can quicky start up a low fire by using the thin stuff.cyberbadger wrote:Well I feel like I am doing something very wrong when I'm using twice as much fuel as that 40 ft boat.![]()
