I am in the process of getting a Lune Valley water tube boiler built. The approved drawings come from the Steam Boat Association's Boiler Library. Unfortunately, the Library is misnamed as it actually appears to hold just the pressure vessels drawings and, in most cases, not the casing drawings.
To overcome this problem I have acquired, by various means, some photos of the casings that other people have built. However, the photos are essentially of the framework. The details of how the whole shebang gets finished is mostly not shown. Using thses photos I have drawn up some thoughts of how to build a frame of pleasing shape with two opening panels for tube cleaning. My feeling is that the frame will end up as a single steel weldment of 20mm square section tube, while the two side panels will be in two parts. The fixed side panels I would envisage being bolted in place (Think boiler inspection!) while the access panels can be secured with over centre clips (think daily brushing out).
The four supports that hold the pressure vessel in place can be simple weldments, again bolted in place to allow a bit of adjustment. [Q - How much space should one allow for expansion that will occur when the fire is going well?] The same applies to the fire bar supports. The wet ashpan is simply a s/s drawer that extends beyond the rear of the casing. There is a lift up lid on the extension that provides the damper function.
The inner lining of the casing can be a single length of s/s sheet with a hole for the firebox door and one for the funnel. I would assume that it would be screwed in place with self tapping screws. The side panels can be similrly lined.
Now we come to insulation. That could be flexible or board on the sides. However, how do we stop the outer covering ending up at fire box temperature? How does one attach the outer covering over the insulation?
Your thoughts would be welcome.
Drawing 1 - Elevations with dimensions
Drawing 2 - Isometric view
