Low Melt Alloy
Posted: Thu Apr 26, 2012 12:51 am
by mtnman
Maybe someone here has a use for this. I have 80+ blocks of this Low Melt Alloy. This alloy melts at 115 degrees. Each block weighs more than 1.5 pounds. I'm asking $19 a block and I'll ship anywhere in the US for free. Contact me for shipping to Europe.
Re: Low Melt Alloy
Posted: Thu Apr 26, 2012 2:21 am
by farmerden
115 F.?? hopefully C. I still have difficulty with changing over!! :lol:
Re: Low Melt Alloy
Posted: Thu Apr 26, 2012 4:27 pm
by mtnman
115 Fahrenheit is the melting point. It will melt in boiling water. One of the uses is to help bending tubing. You plug the tube, pour it full of this alloy and let cool. Now you can bend all you want without kinking the tube. When you're done drop the bent tubing into boiling water and the alloy melts out leaving the inside of the tube clean (it won't stick).
Another use is measuring the chamber of a rifle. Plug the end of the chamber, pour in the alloy and when cool pull the alloy out. You can then mic the alloy to find the chamber size. This alloy does not shrink when cooled. It's really neat stuff!
Re: Low Melt Alloy
Posted: Fri Apr 27, 2012 4:19 am
by 87gn@tahoe
What is the liquid volume of each block?
Re: Low Melt Alloy
Posted: Fri Apr 27, 2012 12:11 pm
by mtnman
I bought a couple of hundred pounds of this and the heater/dispenser at an industrial auction. I used the heater/dispenser to melt it and I cast it into muffin tins. Each block is about 1/3 cup. The heater/dispenser is also for sale.
Re: Low Melt Alloy
Posted: Fri Apr 27, 2012 1:19 pm
Sent PM, I want a few.
Re: Low Melt Alloy
Posted: Mon Apr 30, 2012 5:59 pm
by johngriffiths
treat with care, it may contain cadmium. If you do a search for Wood's or Rose's metal you may find more info.
