Page 1 of 3
Bottle Engine 3D Model
Posted: Thu Mar 08, 2012 3:48 am
by SteamGuy
Here is a bottle engine that I started modeling last year.
Some of you guys have seen this already.
My intent is to use this cylinder on several different engines including a marine twin.
Re: Bottle Engine 3D Model
Posted: Thu Mar 08, 2012 3:50 am
by SteamGuy
Valve is a balanced "D".
Posted: Thu Mar 08, 2012 3:53 am
by SteamGuy
Eccentric and strap.
Posted: Thu Mar 08, 2012 3:54 am
by SteamGuy
Upper cylinder head. (Inside will have a recess at the passage entry to the cylinder, but it does not show up in the model yet).
Posted: Thu Mar 08, 2012 3:56 am
by SteamGuy
Piston.
Posted: Thu Mar 08, 2012 3:59 am
by SteamGuy
The cores will look like this (bore is 3" dia.).
Posted: Thu Mar 08, 2012 4:00 am
by SteamGuy
Cylinder patterns will be something like this.
(This is actually half of the model, and the patterns have to be made by adding core prints, closing up bolt holes, adding draft angle and machining tolerances, etc, but you get the idea).
Posted: Thu Mar 08, 2012 4:03 am
by SteamGuy
Final cylinder like this.
Posted: Thu Mar 08, 2012 4:04 am
by SteamGuy
Rod and bearing
Posted: Thu Mar 08, 2012 4:07 am
by SteamGuy
Crosshead
