Laying Up the Steam Plant
Posted: Sun Jan 01, 2012 6:28 am
This has been one of the warmest seasons ever, but it is time to layup the steam plant against he winter freezing conditions.
I began by removing all boiler connections to the feedwater system, draining all the piping, and applying a high vacuum pump to the boiler. The very low pressures produced by the vacuum pump lowers the boiling point of water to less than 60F (15C) and the boiler steams until all water is removed (evaporated). In the food processing industry this is called "vacuum drying", and it allows drying the boiler without the use of a fire.
For the feedwater system, I put "RV Antifreeze" into the feed tank and worked all the pumps until the prolelyne glycol came thru the pump discharge lines, good to -40F (-40C) without freezing.
Tomorrow I will run the engine with the vacuum pump (connected to the exhaust piping) until all water is gone
Then to wait until the spring season.
