Modern PTFE based oils and greases (Krytox)
Posted: Sun May 29, 2016 11:25 am
Has anyone contemplated using Du-Ponts "Krytox" lubricants (or simmilar) in their steam engines?
There is every possibility that they will withstand working in steam so well that parts could be greased and oiled at services and then left un lubricated while in use as these oils and greases are an order of magnitude better at staying in place on the lubricated surfaces at a molecular level and do not get washed out or emulsify even at elevated temperatures! In industrial use they are used in steam turbines They are also non toxic and in some cases food safe, so ok for the waterways.
Is anyone in a position to know if this is a viable alternative, or to do some wear tests, or has this been done before?
