LH prop Vs RH prop
Posted: Fri Feb 05, 2016 2:38 am
I am looking for a 26-32 X 32in pitch prop. does it matter if it is RH or LH? I suppose this boils down to the question of whether RH Or LH direction is the correct or preferable direction for engine rotation. My engine is a Navy K. This is a two cylinder compound engine and I believe that engine should have a "primary" rotational direction (though i don't know which it should be). Or for that matter any compound, should it have a "primary" rotational direction?
Does this further reduce to the question of "primary" rotational direction for a ninety degree crank?
My wife and I have long ridden a tandem bicycle. I thought (engineer) it would be good to have the cranks ninety degrees out of phase. This would give four pulses per rotation. We rode this way for a long time. I pondered the cycling term "don't pedal in squares, pedal in circles". i believed this was a basic postulate for cycling. If a person "could" pedal in circles, it would be true. But the human leg can only extend with power and thus circling is but a lofty goal which clouds the physical reality which is that we pedal just like a two cylinder ", non compound, steam engine. womp-womp-womp-womp. if we could pedal in circles, the mass of the wheels wouldn't matter. since we can't, the mass of the wheels is the most critical factor to speed.
page two, My stroke force is much greater than my wife's stroke force. Therefore, i set my crank a few degrees ahead of hers so that i initiate each power stoke and she follows a little longer through the bottom.
Here is the difference between the tandem bike and the four cylnder steam engine. SLIP!!!! My bike has no slip, but my boat prop does. whomp-slip whomp-slip . Prop efficiency mandates smooth input force.
Sooo, there is a "primary" rotational direction for a compound twin engine. Which direction is it?
