Page 3 of 39
Posted: Tue Aug 03, 2010 8:06 pm
by stevey_frac
DetroiTug wrote:Flipping it today.. finally!
I periodically scroll through your site to see what's happening! I look forward to updates!
Posted: Wed Aug 04, 2010 1:38 am
http://www.youtube.com/v/XY7nU4sEYlM&hl=en&fs=1
Iron Chief is on her keel. Check out the video, went without a hitch.
Ron
Posted: Wed Aug 04, 2010 6:45 pm
by Edward
I just can't believe that this went so smoothly , that it did is a real credit to you.
my computer is so decrepit that I can't quite make out whether the hull slid round in the slings or whether the slings are attached to the cranes' cable/hook via pulleys . Please put me out of my misery .
Edward .
Posted: Wed Aug 04, 2010 7:48 pm
Edward,
Thanks for the compliment.
Those are two 4" X 30' towstraps with a 20,000 pound rating, and an eye on each end. We just attached the chain through the eyes. So, the hull spun/slid in the slings. The cardboard served two purposes, to protect the straps and to also act as a brake. Cardboard is like a natural brake lining material. If you ever need to haul something heavy in a truck with a slick cargo surface, put cardboard under it, it will stay put.
We backed in the shop afterwards and burned out the strongback with the plasma arc. Only took an hour or so.
I was amazed the flip went as well as it did. I had plenty of time to think about how to do it. The method used seemed the most logical. That same method could be done by simply suspending each sling from above, high enough to allow for the spin. Then use one chainfall/winch to spin it around.
I thought about using an axle above, rolling the slings over it, but there would be no way to control the speed. The bottom being much heavier than the top, it would have whipped dangerously at some point. I didn't want to see that :shock:
Posted: Mon Aug 09, 2010 11:19 pm
Starting to weld up the inside. Hot job, the more i weld the hull heats up and it gets like a big frying pan, coupled with this humidity, not fun. Luckily, it's going pretty fast.
The plan is; weld up the interior, install boiler and engine and take it to the lake and try it out. If all is well, proceed
Image.
I wanted it roomy inside, it is that.
Posted: Mon Aug 09, 2010 11:59 pm
by mcandrew1894
Nice Roll over! no drama.....that doesn't come without some planning.
Well Done....she looks great!
Posted: Tue Aug 10, 2010 3:43 am
by farmerden
Hey Ron It must be nice to have a neighbour with a crane! :lol: After welding everything up will you be painting the inside with some kind of rust preventing paint? Wood rots ,steel rusts,but somehow steel seems much more permanent. Den
Posted: Tue Aug 10, 2010 1:36 pm
Burning out the strongback
Ron
Posted: Tue Aug 10, 2010 1:46 pm
Dave, Thanks, yes it's coming together nicely.
Den, The neighbors crane IS handy :) On hull protection, am looking into getting it galvanized, there is a big galvanizer about a mile away (Schweitzer). The plan was to zinc prime and paint as it may be cheaper. But pricing out the paint, considering the labor, and the superiority of a galvanic coating, I think that's the route to go. I wouldn't even have to paint the interior at all, other than for looks.
Posted: Wed Aug 11, 2010 7:26 pm
by stevey_frac
The roll over was actually very smooth! I was suitably impressed.
She also looks bigger in real life then i had imagined. :D That's always a good sign.
