Fred, Ron, Thanks for the compliments
A couple blasts on the whistle in it's present location will keep the engineer watching the sight glass.
I found an old "trolley bell" or "engine room signal bell" or "boxing bell" (They go by several names) a few weeks ago. It needs to be restored, but that will be in the engine room eventually.
Here is my vision for the funnel and stack, let me know what you guys think.
The opening above the boiler will have a sleeve made 1/8" X 3" flat, that will line the perimeter inside and protrude the roof line ~ 3/4". I will use the existing funnel which reduces down to 6" diameter, that will stick through the opening.
The Stack will be 12" diameter and welded to a rectangular fabricated hood that covers the roof opening(it will also break at the pilot house roof line for towing). The stack/hood will actually be part of the roof and removable for boiler removal, tube cleaning etc. The funnel boiler stack will be standing inside of this. No part of the boiler funnel or stack will be touching anything, with a good air gap in between. Plus, will be exhausting out the stack, so this will create a vacuum at the base of the large stack, pulling air out of and in to the cabin. Plus it will cool the 6" diameter stack. The whistle piping, relief valve standpipe will simply go through the square hood. Sound about right? Which is probably good for summer, if it runs in cold weather, may need to seal off the inside and make louvers on the base of the outer stack for fresh air.
Went and picked up the mahogany for the doors and windows today, the sash cutters sets are here, I'm going to give it a whirl and see how it goes.
Back to the wheelhouse to make upper and lower sills.....
