Hello from Ohio
Dano
Re: Hello from Ohio
Post by Dano »
I drew up the frames for the boat. I added the engine to the assembly to get a better indication of the size. Not a very good picture though.
Dano
Re: Hello from Ohio
Post by Dano »
Sorry about the huge pictures, I resized them but the change must be delayed.
Dano
Re: Hello from Ohio
Post by Dano »
I have not made much progress since my last post. But two days ago, I cut out two more piston patterns for the steam engine. I had a pattern job come up and I already had the stock made, so it was a no brainer. I also posted pictures of my progress on the hull. I added the keel, and used the surface tools to loft it all together.
Akitene
Re: Hello from Ohio
Post by Akitene »
Good evening Dano,
Your hull design is a typical torpedo boat stern (from the end of the XIXth century). Your first post indicates it's based on Reciproca's design, which is lovely. Keep on the good job.
Re: Hello from Ohio
Since your able to change things easily in CAD, you might consider going for a piston valve on your high pressure cylinder. Much less friction loss and easier on the valve gear. Changing to inside admission on that valve is a very good idea too.
Dano
Re: Hello from Ohio
Post by Dano »
Thanks for the suggestion Mike. I will try to make the change.
