I'm thinking the following:DetroiTug wrote:Bart,
Curious as to the intended starting procedure. Seems in a single cylinder Uniflow that with the compression or re-compression stroke that starting could be difficult. Some sort of conventional exhaust poppet valve for starting? That can then be left closed once flywheel inertia is sufficient?
This engine will have steam jackets for the head and cylinders, so getting the engine close to operating temperature involves rotating the engine to mid-stroke upstroke (intake valves closed) and cracking the throttle (which puts steam into the heads) and admitting steam to the cylinder jackets. I'll use a steam ejector/eductor to pull a vacuum on the condenser. Each cylinder drain has two valves in series, one close by the cylinder and another further away; the space between is additional clearance volume for starting. Once the cylinder/heads are hot, with the timing completely retarded (opening perhaps 5 degrees after TDC - for starting) and the first drain valve on top and bottom open and the second closed, I'll bring the engine a bit past TDC and use a small starting lever to open the top poppet valve until the engine rotates enough for the cam to keep the valve open.
The bottom half of the cylinder will have the exhaust port open and be at vacuum. The piston will come down quickly and should provide plenty of power to accelerate the flywheels sufficient to compress whatever air remains in the bottom cylinder, esp. since we're running w/ additional clearance volume and the cylinder was at full vacuum. Once the engine is running (remember, the Kitchen rudder's neutral position allows us to do this w/o the boat moving) the drains can be closed.
Note that the poppet valves will act as relief valves into the heads if we get condensation in the cylinders. As with any larger engine,
warm up will take some time.
If both cylinder drains are open to vacuum, the engine should go to TDC due to different areas on piston top and bottom.
The engine will stay running in the same direction until we're finished with engines; the Kitchen rudder will provide fwd/rev and neutral.
That's the theory, anyway; we'll see how it works when I get this built.
