Re: flexible shaft coupler
Posted: Fri Sep 20, 2013 12:24 am
Absolutely correct on simple U-joints. Without a matched and properly phased pair, there are rotational variations. I suspect, however, that with the flow across my propeller being so non-uniform and with the blades passing by the dead wood, and the torque variations during the normal power cycle of my simple single cylinder engine, that any added vibrations from a U-joint might be hard to isolate from the rest of the flailing about at higher speeds.
At less than a few degrees, it shouldn't be an issue. More than that, maybe line things up better.
For my issues, which are hull flexure and being too lazy to do a really good alignment job, a chain coupler looks like a pretty good solution. And dirt cheap!
