I have always been interested in steam, but never really did much until a year and a half ago when I bought a small non code vertical firetube (VFT) boiler.
I was more or less alone in the woods at the start, learning the ropes running my boiler in the driveway experimenting/learning different aspects of steam operation (different engines, injectors, feed water pumps, making electricity from steam). I found the smokstak website and have been posting there for about a year.
But I knew from early on I knew wanted to build a launch. I just don't have all the parts yet.
I own two candidate engines:
1) A single cylinder simple 2.75 inch bore by 3 inch stroke, slip eccentric reversing running gear, built by John Winn in Abingdon, UK. (It was the engine in 18 ft SL Chimera in the UK)
2) A 1902 Toledo Steam Car simple/single expansion 2 cylinder 3"x4"(both cylinders) with Stephenson reversing gear
The non code boiler I have really doesn't really have the steam capacity for the kind of launch I want to build (It's a dry bottom vft), so I have my heart set on an ASME code VFT from LundMachineWorks.
I will be running non-condensing.
I have various injectors, a simplex pump, a duplex pump, ejector, oillers, etc.
After I get the new boiler, more or less all I'll need is a hull.
I'm not terribly interested in making the launch look authenticly historical, I'm going primarily for functional.
Any ways, that's my story!
