Page 1 of 2
UK source of firebricks/vermiculite panels for boiler ?
Posted: Wed Nov 15, 2017 9:50 pm
by ianrichards
I’ve been looking at the various options of vermiculite panels available over the web, but before I buy is there any particular sort I should be looking at.
I’d prefer to buy a panel and then cut to size as I need some off cuts to make a small brazing hearth.
I was looking at 25mm thickness.
TIA
Ian
Re: UK source of firebricks/vermiculite panels for boiler ?
Posted: Wed Nov 15, 2017 10:07 pm
I would definitely check Black Gates Engineering. A model steam (Keith Appleton) youtuber is always picking up all sorts of great stuff from them.
I'm sure if you call or go in person and tell them what you are doing they can recommend something they have in stock.
Their website references Boiler insulation - but they don't say on the website exactly what they have.
http://www.blackgates.co.uk/index.html
Posted: Thu Nov 16, 2017 9:54 am
Speak to a kiln manufacturer, they have it chapter and verse, and know who supplies what, from where, and how much.
Posted: Thu Nov 16, 2017 11:26 pm
by Mike Cole
Mike Rometer wrote:Speak to a kiln manufacturer, they have it chapter and verse, and know who supplies what, from where, and how much.
Yep to the above, I was given a old kiln, got mine out of that.
Posted: Fri Nov 17, 2017 6:23 pm
by gallanach
Malcolm Duckett sourced the insulation material for his boiler from
https://shop.vitcas.com/
by gallanach
Posted: Fri Nov 17, 2017 7:47 pm
by Mike Cole
Based in Bristol, I see. they seem to have a good range of stuff suitable for building boilers. Should they be added to the SBA website as a known supplier?
Posted: Fri Nov 17, 2017 8:21 pm
by ianrichards
Posted: Sat Nov 25, 2017 5:53 pm
by steamboatjack
Victas are on the SBA directory of suppliers and have been for some time.
Posted: Sat Nov 25, 2017 11:50 pm
by Mike Cole
steamboatjack wrote:Victas are on the SBA directory of suppliers and have been for some time.
I knew I should have checked
