Hello everybody,
I'm not sure this tip has previously been discussed here. Here's a video to illustrate how to neatly & quickly coil a copper tube:
I'm planning to build a Blackstaffe water tube boiler, I'll give this trick a try.
Regards,
Christophe
Making a copper coil the quick and not so dirty way
Re: Making a copper coil the quick and not so dirty way
Pretty "cool" idea
Another way is to use fine sand and tamp the piece tightly full and then fold the ends over. This was just a test piece that bent on one end as I did not use a good means of holding the work.
This was wound a 3/4" mandrel.
I've used both methods, but I have to say the ice one was best for what I did, but you had to be quick, it melts real quick. A little washing-up liquid in the water helps the ice to 'flow'.
I found difficulty getting sand to stay 'tight' inside the tube.
Good tips.
Good tips.
I've used sand to good effect winding coils from 1/2" OD copper tubing; placing duct tape over the ends of the tube retained the sand. I tapped the end of the tube on a wooden block a few times during filling to 'settle' the sand. You want a very fine sand for this.
