Page 1 of 4
Member's Steamboats - A Simple List for All
Posted: Sun Nov 25, 2012 7:14 pm
Thought it would be a good idea to provide a single post boat informal description with a small (under 250K, directly added to the post) picture for each member's boat. If possible this should be sortable, but that is well beyond my computer skills.
Boat Name, Owner, Location
Basic Hull: Hull Type, Length, Beam, Depth, and Draft, Displacement, Construction Materials, Year built
Steam Plant: Boiler Type & Size, Fuel Type, Some Details
Engine: Type, Bore & Stroke, Number of Cylinders, Some Details
Propulsion: Speed, Revolutions per Minute, Wheel Dimensions (Diameter, Pitch, No. of Blades)
Re: Member's Steamboats - A Simple List for All
Posted: Sun Nov 25, 2012 7:35 pm
Steamer Margaret S. Built 2010, Owner: Fred Rosse, Philadelphia, PA USA
Flat Bottom Sharpie Type Hull, 19 foot–3 inches Length x 5 foot beam x 2 ft depth, 7-1/2 inches nominal draft. 1500 pounds displacement nominal. Marine Plywood on Frames, Fiberglass/Epoxy covered.
Vertical Firetube Boiler, 20 square feet heating surface, 100 PSI, 48 tubes 1-1/4 x 0.095, all steel welded construction. ASME Stamped Power Boiler. Propane Fired
American Walking Beam Engine, 3-1/4 x 5-1/4 Bore & Stroke, Double Acting Single Cylinder, Pumps driven from walking beam.
5 Miles Per Hour, Sidewheels direct to engine, 52 RPM, 42 inch wheel diameter, 14 floats on each wheel, floats non-articulated, 8 in deep x 12 in wide
Posted: Tue Nov 27, 2012 9:24 pm
Steamtug "Iron Chief", Built 2010, Owner: Ron Rogers, Detroit, Michigan USA
Classic harbor steam tug, 22 feet long, 96" beam. Keel to gunwale at midship 48", 4500 pounds. Hull material: Steel 3/8 X 4 keel, 1/4" x 2 frames, 1/2" diameter chines, 1/8X3/4 stringers. 12 ga (.105) bottom, 14 ga (.078) sides. Prepped 3mil sandblast. Primer: Interlux 820 Topcoat: Industrial enamel coatings.
Cabins: White oak, Mahogany windows and doors. Lexan for glass.
Vertical waterleg Firetube Boiler, 42 square feet heating surface, 100 PSI, 32 tubes 1-1/2 x 0.125, all steel welded construction. 24" diameter X 48" tall. 19" diameter firebox. Fuel: Wood, 50' economizer in funnel
Engine: 1958 10 hp Tiny Power 3+3X4 twin non condensing.
Pumps: Hypro primary feed pump, selectable .75X.75 crank driven ram secondary pump, Pearl 1" X 2" manual hand pump, Southworth 12" vertical 2" X 1" steam driven and 12 volt Jabsco under floor for filling boiler at 0 psi.
Bunker: Under wheelhouse floor. Roughly 60 sq ft
Speed: 5 to 6 knots cruise. 7 knots at full steam pressure. Turning radius from dead stop: it's own length.
Propeller: 21 X 23 Michigan wheel 4 blade. 1" stainless prop shaft.
Electrical: 12 volt for pumps, spotlight and cabin lantern.
Running lamps: Oil fired.
Steering: Chain driven Teleflex push pull system.
Engine driven Generator: 6 amps at cruise
Amenities: Sink with on demand pump. Fold down flat for Coleman type stove. 10 gallon freshwater storage and 10 gallon graywater collection.
Trailer: Constructed from 3X5X1/4" wall square tube. 30 feet long. Two 5000 pound axles. Electric 1500 pound winch. Electric brakes. Led lights
Posted: Wed Nov 28, 2012 12:15 am
by johnp
S.L. Cardinal Queen, Owned by John Pignatelli, Richmond Hill, Onario Can. 18'3" L.O.A. 5'5" Beam, Plywood With Mahogany and oak veneer decks, interior and decks varished. Built 2011.
20sqft. VFT boiler with 85 1" Tubes, all welded construction. 1/4" tank with 3/8" top and bottom sheet. Wood burning, economizer in smoke hood safety set at 125psi.
Self built, Ray Hasbrouck designed #10, 2.25"x3", 2hp @ 400rpm, non condensing, crosshead driven feed pump, 3/8" Penberthy injector, Hand pump.
Electrics are solar powered, Solar panel on topside of canopy.
Propeller 14"x20" 1" Prop shaft.
Lever steering
Posted: Sun Dec 16, 2012 5:30 pm
by 87gn@tahoe
"Wayward Belle"
She was designed and built by Mr. William Charles Grosjean of Poway, California (near San Diego). Mr. Grosjean designed every aspect of this boat; he also made the patterns, boiler, controls, and engine himself.
The hull is a Chesapeake Bay style open launch, 22'-2" X 5'-10" X 1'-5". Sitka spruce frames and stringers. Honduras mahogany stem, keel, floor timbers and engine bearers. Bruynzeel plywood planking. Silicon bronze fastened and epoxy glued and sealed. Epoxy/fiberglass sheathed. Weight-850lbs
The engine is a 2" & 4" x 3.25" compound on six turned columns, stephenson link valve gear, piston valve on the high pressure piston, balanced slide vlave on the low pressure piston, independent valve gear adjustment on LP. Drip feed lubrication to bearings w/ oil slingers from main bearings to feed rod big-end bearings. Two feed pumps and two air pumps(condensate- 27in/vacuum when no leaks!) and one fuel pump dirven 1/4 engine speed ala Simpson Strickland style gear drive. approx 6BHP@700rpm. Weight-225lbs
The boiler is "once through" monotube, ASME approved design and materials. Natural draught, 21sq.ft./heating surface, 150psi, 450F, 200 lbs/hr. Controls similar principles to Doble "normalizer" control system. Vaporizing kerosene burner, modulated by steam pressure. Steam temperature controlled by quartz rod thermostat. Weight-220lbs
10 and 14 gallon fuel tanks, 3 gallon hot well, condenser: three 7/8" copper tubes 4.5' long.
Propeller- 15"x17" 3-blade
Mum getting warm:
Engine:
http://www.youtube.com/watch?v=nD8_nvSzz2Y
With my father up in the bow:
http://www.youtube.com/watch?v=Ec-oB7_J25s
Posted: Sun Jan 06, 2013 3:42 am
by JonRiley56
Steam Launch Jackie Lee
Owner/Assembler/Amateur - Jon Riley North Kingstown RI
Hull: 22 ft Tanzer Sailboat Hull - The keel had been cut out and the cabin/interior removed. I glassed in the hole and added a mahogany skeg.
Engine / Drive Train: Tiny Power M Single Side Crank. 3x4 Single, double acting with A Stephenson Gear reverse gear. 1.25 stainless prop shaft running through a bronze algonquin shaft log and stuffing box turning a 18x18 bronze three blade prop.
Steering: Original sailboat rudder attached to a teleflex side steering mechanism, with the original tiller available for steering from the stern.
Boiler: 60 sq ft water tube with iron steam and mud drums and stainless steel tubes. The steam line, safety, and whistle etc are attached to a steam dome on the top of the steam drum. The water gauge is a reflex gauge, and there is a single try cock mid steam drum. The boiler was built by LeRoy Metzinger in Seattle and was originally intended for a steamboat in British Columbia. Unfortunaltely that builder passed away before he was able to complete the project. The stack is double walled and the boiler sides are insulated.
Water System: The hot well is a stainless steel tank that was formerly used in a plating operation. It holds about 3 gallons. The water pump is a hypro run via a V belt off a pully on the crankshaft. It is being replaced by a Southworth Steam Pump to allow for water movement without running the engine.
Exhaust - Straight dump thru the side (non condensing) this season to get in the water quickly. Onboard condenser is being installed over the winter. It consists of 50 ft of stainless tubing contained in 6" PVC pipe with sea water for cooling supplied via an electric pump.
This winter will be spent trying to make it less of an eyesore.
I am getting this message when I try to upload a picture :
"Sorry, the board attachment quota has been reached"
Any ideas ?
Posted: Sun Jan 06, 2013 6:01 am
by farmerden
Steam Queen was the dream of George Doughty.After he died in 1991 the boat sat in a leanto til I bought her in 2004.I'm proud to be the "keeper" of her and love Steaming around the Gulf Islands of the Pacific Northwest in Canada.Complete with Head,kichen,and sleeping quarters -a little cosy and definately no chocolate on the pillow at night so maybe only a two star rating!! LOL
She is 25ft with a beam of 7 ft and a draught of 2ft
Made of carvel planked yellow cedar
Engine built by George Doughty is a compound 2.75"X5"X4". Boiler is a Roberts type with a heating surface of 40 sq.ft.
[img]http://i279.photobucket.com/albums ... .jpg[/img]
Posted: Tue Jan 08, 2013 12:34 am
by S. Weaver
Den, very salty! Excellent.
Emma from Germany
Posted: Tue Jan 08, 2013 7:34 pm
by Rainer
The base of Emma is an old riveted steam hull. All woodworking, engine and boiler building was done by myself. You will find some more info about Emma at my steam boat page:
http://www.steamboating.de/emma/steam-b ... -main.html
Please have a look also at my Steam boat register with over 139 boats:
http://www.steamboating.de/boats/aaa-radow-abcalle.html
Posted: Tue Jan 08, 2013 7:39 pm
by boatbum
I hesitate to post my boat's info as it's not steam powered (Atlas Imperial, de'sel). What do you guys think.
Keith
Wes, a little help!!
